Valve Shims - CBR Forum - Enthusiast forums for Honda CBR Owners
LinkBack Thread Tools Search this Thread
Old 05-02-2008, 04:22 PM
axsys's Avatar
Default Valve Shims
hey guys, im getting ready to check my valves on my 02 F4i, and was wondering where the best place to get an assortment of shims would be. are there shims that are specifically for the F4i, or just for Honda bikes in general? thanks!
Old 05-02-2008, 11:33 PM
Default RE: Valve Shims
I just got done doing mine on my 954, I went to the honda dealer and there about 8 bucks each, dont know if there universal or just general for honda's, mine looked like the size of an eraser and were round. hope that helps.
Old 05-03-2008, 02:18 AM
You can go to just about any dealer. I think you are running 7.5mm shims. Each manufacture makes shims those size, and also aftermarket shims. I think though the thing you want to look for are shims that look like they are harden. There are two types of material I think they make shims in. Sintered like sintered brake pads, and hardened metal ones. I was never sure which was suppose to work for what bikes, but if you get the OEM honda ones you can't go wrong. But i think that hot cams, and the other aftermarket ones use sintered type shims.
Old 05-04-2008, 02:29 PM
If you're going to be doing this yourself in the future, you can get shim kits for a little change.
Old 05-04-2008, 06:40 PM
axsys's Avatar
KidCr3nshaw, can you recommend somewhere online to get a kit, or should my local dealer have one?
Thread Thread Starter Forum Replies Last Post
Difference between F4 & CBR954 Valve Shims Conrice General Tech 2 07-18-2012 11:13 AM
Valve shims swaskowiak F2 Tech 3 06-03-2012 08:59 AM
Valve shims mark1200 F4i - Main Forum 7 03-02-2011 02:12 PM
valve shims and adjustment oldschoolsdime92 CBR 600F3 6 11-01-2008 12:00 AM
shims and valve lifters jalate compa CBR 600F2 2 11-14-2007 09:55 PM
Tags
2005, cam, cbr, cbr600f3, change, diameter, difference, f4i, honda, hot, material, onhonda, shim, shims, size, valve
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
