Tire pressure?
After reading a lot of posts last week about the same thing, seems like there is a lot of personal preferance involved. Im just running 35/35 right now. Some of the guys might be able to help you a bit more if you let them know what type of riding you plan on doing, everyday driving etc?
Blake
I'm aware of how different tire pressures are utilized to regulate temperatures on the track. But what purpose would running lower pressures serve on the street? Is it to gain a bigger contact patch, for shock absorbtion, or both?
It's been my understading that in order to obtain the most use out of a tire, pressure should be maintained at maximum.
I run my pressure much lower than that of the maximum load pressure. It gives you more grip as the contact patch will increase, and also form to the roads surface a little better. The lower pressure will also allow the tire to have more evenly distributed heat, which for street driving, is what I want.
I don't think it would matter what pressure you run if your not overly aggressive, but I truly believe it makes a difference when you start getting aggressive in the corners. My bike feels much more planted with air pressure lower than max. My last pressure I ran was around 32 front, 34 rear. My bike is very happy at those pressures.
I think running the tire at max load will give the most mpg out of your bike because of less rolling resistance, but not the most grip or even the most mileage out of the tire. With pressure too high, (as in max load), the tires contact patch is small, creating heat concetrated in the center of the tire. The tire heats mainly in the center, and can actually wear out faster where lower pressure will spread the heat out over a wider range of the tire. Of course, there is a ballance, you can go too far in either direction.
having said that, I dont think the max load is wrong, They have to cover their butts. If you load up your bike to the max load, run lower air pressure in the tires and have a tire failure, the manufacturer is to blame, so they have to cover themselves, and for the majority of riders out there, max pressure is fine. If you start riding the edge of grip, its your fault if you crash, not the manufacturers. If the world wasn't so sue happy, we could probably get realistic pressures for weight ranges.
anyway, thats my thoughts on it.
