Speedo semi working
Old 10-13-2014, 05:43 PM
drag900's Avatar
Registered Users
Default Speedo semi working
I have a 98 CBR900RR. I race with this bike. The speedo will work up to about 100 MPH, then after that nothing. When I go back below approx. 100 it will start working again. The speed sensor looks good, from what I can tell from taking it out.
Any suggestions, thoughts?
thanks.
Old 10-19-2014, 08:48 PM
Is the speedometer factory ?
Old 10-21-2014, 05:31 PM
drag900's Avatar
Registered Users
Yes, everything is still stock in the gauge cluster.
Old 10-22-2014, 05:50 PM
NRWhiteKnight's Avatar
Is it cable operated or electronic (has a speed sensor). If it is the latter it could be a faulty sensor or if it is cable operated then it could be the cable is slipping either at one end or the other. It could also be the speedo, but will need a little more info to help troubleshoot via the web.
Old 10-22-2014, 07:19 PM
drag900's Avatar
Registered Users
The bike has a speed sensor. took it out looks good to me. disconnected the plug and put an ohm meter to the plug turned on bike and got a reading a little above 11. don't know what it should be but to me its getting power. how can you tell if its bad sensor.
Old 10-27-2014, 09:53 PM
I don't have a wiring diagram for a 900 or a manual. But I imagine your speed sensor is like the F3's. It has 3 wires going to it, 12v, Gnd, and an output. That output should go from 0-5v as you rotate the rear wheel with the bike supported and rear wheel off the ground. You'd have to check a manual to be sure of it's operation.
jakenok
06-12-2011 02:02 PM
allenpa5
07-03-2008 11:12 AM
jardine
05-10-2008 06:34 PM
troyg3
06-11-2007 05:40 PM
SKDiablo
04-05-2007 07:39 PM
Quick Reply: Speedo semi working
