NC23 blew up - questions on repair
thats not bad at all. Ive removed the sump and the clutch cover, as while the engine is out I figured id make sure i get all the swarf and debris out, and have a general tidy up of what's left.
some of the old gaskets are pretty stuck on, so I might try and douse them with kerosene or something to see if they soften a bit so theyre easier to remove later on before reassembly
well a new complete head, barrels and piston turned up today. Ive also ordered the gaskets, which are on the way, and four new sets of rings as well, since its a small expense and makes sense since the motor is in bits.
Guess now I will have to do clearances again since its a new head, hopefully this one is in better condition!!
I am going to strip the carbs completely again,a nd soak everything in carb cleaner too. mostly just to keep myself entertained until everything turns up.
progress slowly being made.
gaskets arrived, as did rings.
i bought a compressor as ive been wanting one for ages. I stripped the new head, and cleaned it up. I have lapped the valves, and fitted the replacement piston.
Ive used gasket stripper to remove remains of old gaskets from all mating surfaces, and degreased and cleaned up the sump and clutch side covers.
Sump has been refitted with a new gasket.
Ive been in touch with one of the former owners, who said he has a gasket kit for it as well, which he is apparently sending me. I mgiht wait till those turn up, and see if they look any better than the chinese gaskets I had arrive the other day, before deciding which ones to use. Either way I suppose I will have an extra set on hand in case it all goes bang again!
will hopefully get some more done this weekend.
