topspeed for sprocket
Old 10-16-2006, 08:26 PM
Joker_101's Avatar
Default topspeed for sprocket
Whats up guys I'm new to the forum, my name is Daniel.
I have a 16t 45t setup, I know stock is 16,43, my question is
how much of my top speed is lost with the mod? I have a 2000 R1,
I know I'm on the CBR site, but I cant post on the Yamaha site
and the Honda uses the same chain sprockets.
Old 10-16-2006, 11:53 PM
Default RE: topspeed for sprocket
Keep your yamaha **** off of here!!!
No just messing man, I would guess that if you went up 2 in the rear, very little top end loss will occur, if any. Hell, if you have a larger diameter rear tire than stock, it might actually help.
Old 10-17-2006, 12:52 AM
goin up 2 in the rear will drop top speed a little but not much. have you ever had it to top speed before the sprocket change? if so then you'll probably top it out with the new sprocket and will be able to answer your own question. if you haven't with the stock sprockets then I don't understand why you're concerned with what it'll be now, since you probably won't have a need to go that fast (170+). on a side note, if you do decide to go warp speed please do so on a track.
Old 10-17-2006, 07:51 AM
woot's Avatar
OLD
16/47 = 0.34042553191489361702127659574468
DIVIDED BY
NEW
16/45 = 0.35555555555555555555555555555556
95.7 percent
Basically - you loose 5% of your top speed. 100mph is now 95.7
Myfirstcbr
03-22-2013 09:40 AM
Stags4
10-08-2008 08:43 PM
Quick Reply: topspeed for sprocket
