f1 ignition
Old 10-04-2006, 05:39 AM
Junior's Avatar
Default f1 ignition
i cant find an ignition specifically for an f1 will a f2 ignition and gas cap work? lost the dang key so i busted the ignition, was moving needed to be able to move it left steering locked. i have a 1990 f1, thanks
Old 10-04-2006, 02:50 PM
rrasco's Avatar
Default RE: f1 ignition
not sure about the ignition. i have asked about the gas cap before and no one really told me. the only conclusion i have come to is it probably will since you can by universal keyless caps for F1-F4.
if yo go here and look at them you will see what i mean:
http://www.targa-acc.com/
i have not tried and am unsure oh how they BOLT up, with newer caps there is a base that stays, and only the center is removed. as where our entire cap is removed. i am not sure if the base bolts to the tank, or if it is more of a clamp type bolting. i was going to try with an F2, but just have not yet. let me know if you try.
Old 10-05-2006, 03:30 AM
Junior's Avatar
can anyone tell me if the plugs are the same?
Old 10-05-2006, 12:20 PM
rrasco's Avatar
which plugs, the spark plugs?
NGK Spark Plug: DPR8EA-9
Old 10-05-2006, 09:57 PM
Junior's Avatar
na the plugs for the wires comming out of the igintion
dylanhunter
12-05-2013 04:13 PM
Alex Poucher
02-14-2013 09:29 AM
DagonRais
04-14-2011 09:32 PM
importluva85
09-21-2007 01:32 PM
Quick Reply: f1 ignition
