Died on way to work
Old 08-19-2014, 09:05 AM
knapp016's Avatar
Registered Users
Default Died on way to work
Made it a hundred feet from work. when slowing down it started to sputter gave it gas and died out. Put it in neutral, all the lights were still on, hit the ignition switch, and nothing. Didn't even try to turn over. Gauges dimmed a little and gas gauge went up and down but nothing else. Took the fuse out for the starter and it was fine. Tried starting it again and the starter engaged for a hair of a second and that was the last of it. Any ideas? I put in a new rectifier this summer and that fixed all the previous demons. And removed the gas pump, that died and been running gravity since but had no problems.
Old 08-19-2014, 09:26 AM
Mattson's Avatar
Would help to know what bike are we talking about. Could be a loose ground somehwere.
Old 08-19-2014, 09:34 AM
Conrice's Avatar
I wouldn't think it has anything to do with the gravity feed since the starter is barely engaging. Like Matty says, check your connections since it sounds like an intermittent issue and go from there. How long is your ride to work?
Old 08-19-2014, 09:40 AM
74demon's Avatar
Sounds like a dead battery. Battery may be shot, it's not charging, or both.
Old 08-19-2014, 06:17 PM
knapp016's Avatar
Registered Users
My bad cbr f4. 1999. Just got outta work....... Started right up. This leads me to think it's the rectifier all over again
Old 08-19-2014, 06:25 PM
knapp016's Avatar
Registered Users
Alright so went around the block then same thing stalled and won't start again. Can't see anything outta place after a quick look over. Gonna get the voltmeter and diagnose on my day off
Old 08-20-2014, 08:50 AM
Conrice's Avatar
That leads me to think it's a connection.
Old 08-21-2014, 04:18 AM
wheelnut's Avatar
Welcome Crew
+1 with cornice if its intermittent I would say a connector or earth
Old 08-23-2014, 11:18 AM
knapp016's Avatar
Registered Users
Will look into that to. Any known problem spots
Old 09-02-2014, 09:10 PM
Drumsergeant's Avatar
Well I know on my F3 the 3-wire connector between the stator and the R/R was shotty.
Er... Still is. But that could be an issue.
If its sputtering try checking the fuel vent lines, if there's a kink it'll create a vacuum in the tank and your aftermarket "gravity" system won't need much vacuum to stop flow.
Quick Reply: Died on way to work
