Crack in enginge block by stator cover
Old 04-13-2016, 02:29 PM
Pmartone's Avatar
Default Crack in enginge block by stator cover
Guys.. I took a spill and have this crack in my engine block. Its at the top of the stator so I'm hoping it won't leak as much oil. What are my options? jb weld? lol
http://i76.photobucket.com/albums/j2...psl0u2tref.jpg
http://i76.photobucket.com/albums/j2...ps2qoqx3y9.jpg
Attached Thumbnails Crack in enginge block by stator cover-00c0c_hnmss883e03_600x450-1-.jpg   Crack in enginge block by stator cover-00w0w_j1azw4kuisj_600x450-1-.jpg
Old 04-13-2016, 02:55 PM
74demon's Avatar
It's on top, so it doesn't see much oil.
I would put a new gasket and swipe some sealer on it from good hole to good hole. You probably will be okay.
Old 04-16-2016, 04:02 PM
sjona2011's Avatar
im assuming you're talking about the chunk missing from the bolt hole?
either new gasket and/or rtv on it. or find someone who can weld it so it can be drilled and tapped
Old 05-28-2016, 04:57 PM
Sam Scaife's Avatar
Hope I'm not to late but I agree. New gasket or gasket former would be ok. Stator case is not very high oil pressure. (I read that from another post.) I used blue gasket former and followed the instructions and never had an issue. The weld could work but it would require even more time and money than a gew gasket. (One bolt is ok... but three or four no go. Lol)
neeganate
07-08-2013 10:04 PM
Mr. B
12-27-2011 11:29 PM
cbrtripleblack
12-16-2009 10:29 PM
cjwill123
06-11-2009 06:37 PM
p8ntballer99
03-31-2008 02:08 PM
Quick Reply: Crack in enginge block by stator cover
