Clutch Engagement Rondomly Changed
Hello, this is my first post on this site and as such I apologize if this is in the wrong section. I have a 2006 cbr1000rr and it has been in my garage since the beginning of November. I went to move it so I could fit one of my cars in and the engagement point of the clutch moved. I have asv levers on it if that's of any usefull info. When I put it in first gear the rear tire spun(dirt on the floor). I had to adjust my clutch lever a bit obver two inches out from the end of the bar. I haven't changed anything and the times I went out to look it over before then have all been fine, but it seemed to have moved anyhow and I can't think of a reason why it would have. If anybody has had a similar problem or any advice on the situation I would be thankful for any help. If any more information is needed I can provide that as well.
I did notice I was able to move the lever closer to the position I had it before after it ran and I got it moving a bit, thank you for helping this issue make sense to me.
supersnake83
07-05-2009 01:56 AM
