Brake Light problem, new bike owner
Sup everyone. Just picked up a "new to me" 2003 CBR600RR. The guy that had it before me built it at a stunting bike but didn't actually end up using it as he wasn't as into it as he thought he would be, plus he was a soldier and was never home to ride it. Some of the street stuff was removed on it and I'm trying to get it back to street legal. This is my first street bike but I've ridden dirt all my life and I'm trying to get it back to street legal. One of the things that was taken off was the brake light. The little connector for the brake light was cut off so I did cut the connecter off the brake light so I could hook it up to make sure it was still in working order. The brake light comes on, but it stays lit like someone is pushing the brake all the time. What would cause this? The rear brake wire isnt connected to anything. Also with the CBR does both the front and back brakes light up the light? This had a hand rear brake also, would that set it off?
Here's some pics to help
Here is the rear tire hand brake
rear brake pedal (not connected). Anyone know where I could get the wired that connects the back brake? Does the wire thats missing run to the back of the bike or front?
Brake Wired up (temporary wiring)
Thanks for any help folks. I know this seems super scattered but ill do my best to give as many details/pics as needed to try to get it going.
on
1 Post
Both front & rear have an activation switch. rear is adjustable (for when you adjust the brake pedal up or down) & front is not. Not 100% sure, but the reason the brakes light is on could be that their disconnected or the rear brake switch is adjusted to far so its on. Its located above & behind the rear brake pedal.
The one that plugs into this
It shouldn't stay lit if the back brake switch is disconnected. These switches complete a circuit, so if the switch is missing the circuit will not work. So, if the brake light remains on and the rear brake switch is not connected, the problem is probably in the front brake switch....it is sticking on.
