bike wont start after warm - CBR Forum - Enthusiast forums for Honda CBR Owners
Thread Tools Search this Thread
Old 09-01-2009, 03:01 PM
Default bike wont start after warm
need help please...recently my bike won't start after I have ridin it. My bike has no problem starting when its cold. But after I have warmed it up and ride it, it will not start again after I turn it off. No crank nothing...I would have to wait about 10 to 20 minutes sometime to be able to start it up again. can anyone help?
Old 09-01-2009, 04:08 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Info please ... what model?
Old 09-02-2009, 02:09 PM
I have a 2002 f4i...i also noticed that my bike gets hot around the frame by the gas tank. like really hot ! and my fan dont kick on til about 220 temp. is that normal?
Old 09-02-2009, 02:31 PM
Those are both normal. The frame gets hot due the the regulator/rectifier and the fan should kick on around 220F and go off around 205F.
When a fuel injected bike won't crank when warm it's usually a bad sensor. Either the MAP (manifold air pressure) sensor or the IAT (intake air temp).
Get a hold of a manual ... it will have the specs for you to check out these sensors with a meter.
Old 09-03-2009, 03:52 PM
kool thx! I will check those out and see. I appreciate the help...I was a lil worried about the heat temp and fan so I got it running always now. I'll fix it back. lol
Old 09-09-2009, 10:37 PM
I have the same issue with my 2002 F4i. I don't think it
s my rectifier because it looks like it's been changed with a Gixxer model. I have to try and bump start the bike. Sometimes it works and when it doesn't I sometimes hit the switch after I've rolled it down the street a bit and it will fire up but really slowly like it wants to die again from lack of voltage. I'm thinking I may have a bad battery.
My whole dash will reset as well. If I hold the starter button down it will crank just a bit and everything will turn off until I release the button then everything will come back on. The starter will not continue to click as if it has low voltage.
Could it still be one of the sensors?
Thread Thread Starter Forum Replies Last Post
Bike will not start when warm cmasonrun General Tech 5 09-01-2008 04:08 PM
turns over slow and wont start when warm wentsCBR CBR 1000F "Hurricane" 9 08-26-2008 07:20 AM
f4 stumbles on start after bike is warm brett82 General Tech 2 07-27-2008 01:04 AM
Start-Up Problems (Bike Warm) HurricaneRider General Tech 5 04-14-2008 12:32 PM
Start-Up Problems (Bike Warm) HurricaneRider CBR 600F 5 04-12-2008 06:31 PM
Tags
600, bike, cbr, crank, doesnt, f4i, hot, motorcycle, run, shutting, start, starting, stats, warm, wont
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
