Bike won't kick over with new battery
Okay my problem I have is on my 08 CBR1000rr the bike will start using a jump start but won't with out the boost my battery is brand new top of the range CCA 195 AH6.5 should be no problems with the power of battery, All my fuses are fine, My stabiliser is fine I don't know where to look for go from here ether starter motor or stat anyone had this problem.
Have you looked at the 30amp fuse on the starter relay switch/solenoid, if thats ok try bridging the starter relay posts to see if the engine will turn over, if it does then you need a new starter solenoid, watch out for the sparks and dont bridge to long, you can find a video on how to do this on Youtube
Jubex7
03-18-2013 07:57 AM
