air pressure in the tire?
Old 10-25-2006, 09:27 AM
ameersak's Avatar
Default air pressure in the tire?
hi guys.just a quick one.i live in the middle east, Dubai UAE, what is the correct air pressure for the tires..both front and rear..thanx.
ameer.
Old 10-25-2006, 11:37 AM
Default RE: air pressure in the tire?
I think everyone runs different pressure...? but I run 28-30front and 28-30rear...Not sure if this is right but It seems ok...
Old 10-25-2006, 01:17 PM
what bike are you riding??
If your riding an F2 -F3
Front tyre 120-60-17, 36psi
Rear tyre 160-60-17 42psi
no more no less unless you have a never ending money supply to keep replacing your tyres.. you can go less on the tyres but mainly for track use only, I would't reccomend it for street use though
Old 10-26-2006, 01:20 AM
dragonium25's Avatar
Depends on how you ride. Softer gives you better traction, but more wear. Harder, well...gives you the opposite of that. I believe the manual states 40 psi (cold) front and rear. Right now I'm running 32 front, 34 rear.
Old 10-26-2006, 01:34 AM
Bobthebiker's Avatar
yup, if you like to ride up on one wheel, lower pressure is better in the back tire, but for normal street riding, I would go with what the manual says to use.
but what bike are you on, and what kind of riding are you doing? stunting, racing, or just regular cruising?
Old 10-26-2006, 01:47 AM
bushmasterAR15's Avatar
I filled em up to spec, man they feel hard. No problems yet though.
Old 10-26-2006, 11:35 PM
it is always a good idea and highly recommended to split the pressure by two pounds from frount to rear. no matter if you like them soft or hard you need the two pound differance. I run a 929 with Q's 38 rear - 36 front.
I sencond what dragoniun25 says.
Old 10-27-2006, 01:48 PM
Jaybird180's Avatar
I ride 32/38. I've been doing more straight stuff lately and can see some rear squaring, thinking of bumping up. Otherwise I've got good traction on my well used D208's.
scorpionvmu
02-19-2011 12:00 AM
phillycbr
10-20-2009 08:56 PM
Stay2ned
08-06-2008 08:17 AM
Ripper44
02-13-2007 07:49 PM
canadianF4i
09-12-2006 03:06 AM
Quick Reply: air pressure in the tire?
