2003 F4i 600. Motor swap. No fuel or spark. PLEASE HELP!!!
Old 07-24-2016, 11:40 PM
jsw0021's Avatar
Default 2003 F4i 600. Motor swap. No fuel or spark. PLEASE HELP!!!
Recently purchased cbr that jumped time and bent all kind of valves and stuff, I pulled the motor twice and replaced all of the valves and it keeps blowing itself apart. So, I found a used motor that is supposed to run and just did a motor swap. The old motor would fire up and idle but it sounded like it was going to explode. Anyway. So I've got the new motor in the bike. Hooked everything up just like I have done in the past, and now I'm not getting spark. And also the injectors will not let fuel in the bike, I know this because I can try to crank it, I hear the fuel pump, then when I take the gas tank back off and unhook the hoses it sprays pressurized fuel all over my garage. I am standing in my garage about to set it on fire. Please help me anyone
Old 07-25-2016, 05:34 AM
74demon's Avatar
Check the fi fuse.
Make sure the big plug for the coil/injectors is plugged in.
Make sure you headlamp is plugged in and working and the bas circuit is good.
Old 07-25-2016, 06:28 AM
Conrice's Avatar
I'm sure you're just missing something simple as demon suggested...
Old 07-25-2016, 12:21 PM
jsw0021's Avatar
Thanks guys. Going to check it now
Old 07-25-2016, 02:23 PM
jsw0021's Avatar
Originally Posted by 74demon
Check the fi fuse.
The fi fuse is good. Big plug is in. Everything is good. The code is for cam pulse generator. Can anyone tell me where that is??
Old 07-25-2016, 06:17 PM
jsw0021's Avatar
it was the ignition pulse generator. Fired right up. Thanks so much for the help
Old 07-25-2016, 06:24 PM
74demon's Avatar
Didn't know there was a code...
Old 07-25-2016, 10:51 PM
Conrice's Avatar
Glad to hear. Knew it must have been something simple.
baseballkid
10-04-2012 07:48 AM
little_leon60
07-20-2006 02:58 AM
little_leon60
07-20-2006 02:41 AM
Quick Reply: 2003 F4i 600. Motor swap. No fuel or spark. PLEASE HELP!!!
