2001 929 wont start help!
RE: 2001 929 wont start help!
My bad. When I stored the bike it had a full tank of gas...when I got back first thing i did was take the old gas out..and put new gas in..even be4 i started it. and no it wont turn over at all. I just got back I havent had a chance to check anything out yet, wish I could give more info. Thanks
Ok, that's at least a start. Check your fuel screen first off. You'll have to empty the tank again, but make sure the screen is clear and not gummed up. If it is, use some gas/solvent and an old tooth brush and you can clean it out. (the screen is inside the tank attached to the petcock assembly).
It's most likely a gumming/varnishing problem that you should be able to solve fairly easily.
Check your plugs/wire brush them. Again, make sure the petcock is open, and give it a couple throttle rolls inbetween each firing.
If you have trouble past that, let me know and I'll see how much I can walk through everything I can with you.
C Jacob W
07-29-2013 11:03 AM
