2 dead cylinders #3 & #4 good compression and spark
Ok so i just bought a 94 cbr 600 that tboned a car, frames untouchdd and mechamiclly shes ok other then those cylinders. and mainly the damage was the plastic is trash and the front forks are done for. When i bought it it had those 2 dead cylinders. Just to know what i bought i took the heads off and did a leakfown test. She looks 100% so i put her back together and she has 120 Compression in each cylinder. I tested all the plugs on the frame to see the spark and they were weak so i got new plugs. Once i put the new plugs in she ran on all 4 and sounded perfect and badass. Next thing i know 30 min later shes back to 2 cylinders and gas seems to be leaking from the o rings where the fuel connects on the left side of the carb. The good side. Or at least that area. I cleaned the carbs and same issue. I need second opinions
Just pulled the plugs, both were dark and wet and I put them in brand new so they are getting fuel. Fixed the gas leak it seemed to be just the seeping out the float bowl gasket. I tested each plug on the frame and each has a good spark. And I know its getting fuel. I also just cleaned out the carbs with no change. Compression, fuel, spark. Stumped. also I am so confused how I got it to run on all 4 just for a little while by changing the plugs, the wires are on there well and have a good connection to the coils.
Any ideas guys common lol
Hi evidently your getting fuel to those two cylinders, you also got a spark, maybe your getting too much fuel to those two cylinders, best thing i can suggest is to take the carbs off and see if you can get it to run on those two cylinders by squirting carb cleaner into the intakes, still could be the carbs
Hi , have the mixture screws been adjusted, or are they capped, by the looks of it your in the US ( I'm in UK) they should be set at 2 to 2 1/2 turns out from seated, but if their capped , then their at factory specs
https://cbrforum.com/forum/general-t...estion-129989/
