03 honda cbr954rr fuel pump wont prime
Hi to everyone it has been a while i have a problem with my 03 honda cbr954rr i rebuilt the engine & the bike started once after that i wasnt getting any fuel pump priming the tip over sensor was faulty i replaced it the ignition switch was faulty i replaced it & still i wont get no fuel pump prime & no spark the ecm is good i got it checked cant seem to find the problem can sum one please give me sum help thanks alot my fellow riders.
I got the ignition switch from partzilla.com. I am getting between 9.5 & 8.5vlts but it doesnt go below 8.5volts or it doesnt go above 9.5vlts on the pink wire i guess that voltage is ok anything lower or higher i guess the diode is fried. When i first rebuilt the bike it ran for 15mins good so i stopped the bike & went for more gas when i came back & filled the gas tank & tried to start it but no fuel pump prime unless i put direct 12vlts to it.
Spark problem
Heyyyyy there 74demon i found the problem it was the servo motor the wires were jacked so thats y i wasnt getting any fuel pump prime or spark i unplugged the servo motor & the fuel pump primed & i got spark so too any one else who encounters a no spark or fuel prime on there cbr do all ur major checks & please dont forget to check your servo motor please thanks again 74demon have a gr8 one fellow riders & keep revving your hearts✌.
I switched them around & got spark on # 3 coil but only for a short time but still no spark on # 4 so i will check the power wires that are going to #3 & #4 coils & see if they have any breakage in the wires & repost with my findings
