Front brake rotors
Did you check out your wheel. the run out there ? Just to make sure its not the wheel. Im just assuming you did.
Either way. I was just looking through them the other day here. A few OEM pairs around here and there.
F4i rotors | eBay
F4i rotors | eBay
I guess you're not familiar with a dial indicator. So take a sharpie put it against your fork like a cross with the tip touching a rotor. Hold it in place without moving it, now spin your wheel. Of course you need the wheel off the ground to do this. You should now be able to see how warped it is. Sort of like, kind of.
Methinks more troubleshooting need you do.
Get the wheel in the air and spin it. It should spin fairly freely, with just a hint of brake drag. If it doesn't, find out why instead of immediately throwing (questionable/used) parts at it.
Took it on a group ride and one of the guys looked at and pretty much confirmed my suspition of what it is. Needs new pads all around. I've got them on order so hopefully that'll fix it. I might order new wheel bearings just to be sure it isn't those. Anyone have any recommendations? Seems the only ones I can find are All Ball or something, I'm not familiar with wheel bearing manufacturers.
Any help would be greatly appreciated, thanks in advance guys.
