F4i - For-Sale / Trade Post up your extras here. Forum rules apply: Senior member, pics, price and location.
f4i ecu, radiator, shock, throttle bodies, brakes and more!
Old 04-18-2014, 02:26 PM
cynicalrider's Avatar
Bump. PM me if you need anything as I don't check here often.
Old 06-16-2014, 11:53 AM
Bump, still got stuff for sale
Old 06-17-2014, 06:07 AM
NewSense45's Avatar
You wouldnt happen to have the starter kill switch and turn signal/horn things for sale would you?
Old 06-17-2014, 10:09 AM
Only what's in the thread.
Old 07-08-2014, 09:28 PM
thirdgenlxi's Avatar
Ironmang
Still got the throttle bodies?? Do they have the little rubber boots on the bottom (that attach to the head)?? Replacing mine because of a cold start idle problem that I can't seem to figure out (already replaced thermowax valve, vacuum hoses, etc).... was there any problems with it going into fast idle when started cold?
Old 07-14-2014, 02:08 AM
AirmanSkee's Avatar
Do you still have the radiator fan for sale? Are you sure it operates? Mine is looking like I need to replace it, as I've troubleshot just about everything else and can't get the fan to kick on even with direct 12v power.
Old 07-14-2014, 10:21 AM
I still have the throttle bodies, I'll check on the boots.
The fan worked when it was removed, I'll test it on 12v.
Old 07-14-2014, 07:33 PM
AirmanSkee's Avatar
Okay thanks. If it is operational (even if it will turn on by just 12v, I will be hardwiring a switch on.) Then I am interested. Should fit in a small flat rate box, unless its cheaper to ship another way to 99506.
Old 07-17-2014, 07:22 PM
Sorry for the delayed response, test it on 12v today, works like a champ.
$40 shipped?
paypal michaelhalat@mjhcreations.com and I'll ship tomorrow.
@thirdgen this is what I have regarding the throttle bodies:
That's both sides.
Old 07-22-2014, 02:38 PM
bump
Quick Reply: f4i ecu, radiator, shock, throttle bodies, brakes and more!
