ticking noise--not cct
The ticking noise isn't dependent on engine speed. The noise is vehicle speed related...The faster I'm going the faster the tick noise, no matter if I'm in neutral or first.
I tried a search but only came up with two possibilities.
1.)cct= That's not the noise
2.)normal chain noise = not likely, my buddies f3 doesn't make the noise.
2005 f4I 2200 miles.
The noise is real faint when driving down the road, but when echoing off of a bridge or other cars next to me the noise gets real loud.
When cars pass by it sounds like it's coming from the rear, but can be heard from what sounds like the middle/front of the bikewhen cruising around. To better describe the noise it sounds like brakes on an automobile when the pads get to low. Not the high pitch squeek when they get real low, but the tapping noise they faintly make when tapping against warped rotors when 10-15% pad life is left...
RE: ticking noise--not cct
my bike makes a clattering noisefrom right under the gas tank when i go wfo at lower rpm's, say 4000-7000. sounds like my wife's corolla when you load the engine at low rpms. i hope its not the valve clearances cause there's no way in hell i'm checkin um untill 15000[&:]
Thanks, guys. I'll try to tighten up the chain. Like I said it's vehicle speed related, not engine speed. I highly doubt it's the valves, I'll check the chain and if that doesn't work I'll rule out all engine/transmission related issues next.
BTW: how often is a chain adjustment/replacement needed? I remember on my old fzr you had to replace the chain almost annually. Once you had to adjust it once, it just kept stretching. Then again I always bought el-cheapo chains. I'm assumming an oem chain should last 2-3 years at least if kept adjusted properly??
