Stranded in sun, fuel pump won't kick on?
Any help would be greatly appreciated let me start off with that, I rearended someone very low speed bike fell over, bike turns but won't turn on, tilt sensor looks fine, fuel relay is bypassed so not an issue, I checked fuses nothing wrong there?
Am I missing something ty
By turns, I'm assuming there is power.. if so, is there enough of it?
-are you able to push start the bike?
-Physically the tilt sensor looks fine but are you sure it isn't damaged internally? I'd say thats probably the first place to test and not just by looking but testing it.
Do you have the FSM?
Tks guys yes it was the bank sensor when bypassed the fuel injector kicked on, only thing now tho is when I turn on the bike the fi signal goes away but after like ten min of riding it comes back? Bike runs fine with no affects but worries me, turned it off and back on still same exact effect any ideas?
Hmm well I never got the chance to trouble shoot since my speedo wasn't working right I had to get my aftermarket piece checked out since it fixes my speed due to my larger sprocket and when I went back to factory my speedo worked(with mph fluctuation) but the code or fi signal hadn't come back
Kopi Ko
10-01-2019 08:29 AM
