Please help bike wont run cold
Old 03-03-2017, 02:03 PM
Randall Bowman Williams's Avatar
Originally Posted by 74demon
Not really a common thing. Usually the problem is a high or surging idle that's caused by low coolant or a blocked coolant line. If the air got hot enough to be an issue, your bike would be the least of your problems.
I just flushed the radiator and the antifreeze that was in her was super super clean with no sludge or particles so I probably didn't even need to do that, do you happen to have a part number for that wax unit?
Old 03-03-2017, 02:26 PM
74demon's Avatar
16044-MAT-E01 ELEMENT SET, WAX
16011-MAT-E01 GASKET SET B
You need to rebuild it. If the case is no good:
16502-MAT-E01 CASE SET, WAX
Reference this page: Honda Parts Finder | Honda Parts Direct Palestine, TX (888) 446-6325
But you really need to make sure the linkages are all fine ad see if it moves when the bike gets warm.
zbonfilio
07-06-2010 02:39 PM
kilgoretrout
The Hurricane Saloon
22
04-27-2009 09:02 AM
transambird_2000
11-24-2008 08:53 AM
mishab
09-07-2007 01:00 AM
Quick Reply: Please help bike wont run cold
