Jacking bike up off the ground
Should be fine with stock exhaust. Use a block to spread out the pressure point on the headers. I've also use ratchet straps to support the bike from the ceiling. Just don't use your garage door rails - they're weaker than they look.
I'll try and get something back to you tonight on the other stuff we discussed.
But stands hold the bike up from the forks and swingarm. Stands won't do what I need if I want to take weight off either of those to do work the suspension.
If you've got a set of junk forks and extra shock, you can put those on temporarily. In your case, you have to take the weight completely off the front to get the upper and lower bridge undone from the frame. Make sure you use straps to help stabilize the bike in case of a tipover or pressure put somewhere when parts are being R&R'd.
For the front they make triple tree stands for this exact reason. For the rear I've always prefered lifting via the subframe and some straps.
