Intergrated Tail Light Problems
OK so i found a write up under the How-to section on how you can make your stock tail light into an intergrated with some rewiring and a couple automotive relays. I followed the directions and the wiring diagram and did the right side and it worked fine. Then i went and did the left side and everything works except the Bright brake light (when you hit the brakes). I am going nuts trying to figure it out and cant seem to find the problem so any help or ideas on how to fix this would be awesome. Heres a picture of the wiring diagram i found on the how-to section to do this.
What you need to do is go to your local parts store, advance auto parts carries is where i got mine, and buy one of these http://www.ronshomeandhardware.com/P...274&Click=1014
you can ignore the wires for the running lights.
