Installing frame sliders
Old 01-02-2017, 05:10 PM
Jaybird180's Avatar
Default Installing frame sliders
It's been awhile since I did the last set so I'm seeking a bit of memory refresh on something. When I remove the bolt that mounts the engine to frame to install a slider, does the engine need to be supported to put the bolt back in place?
Thanks guys
Old 01-02-2017, 07:52 PM
sjona2011's Avatar
as long as the rear mounts are in place you wont need to
Old 01-02-2017, 10:13 PM
coalminer frank's Avatar
Dont do them both at the same time. Remove the 1st frame bolt & install the 1st frame slider then remove the 2nd frame bolt & install the 2nd frame slider. If you remove both at the same time it might drop just a coochy hair to much to allow installation of the new bolts without support from underneath.
Old 01-03-2017, 08:55 AM
Jaybird180's Avatar
Thanks fellas. That's what I was hoping you'd say.
kiggy74
How-To: Mechanical
61
09-03-2011 09:56 AM
cbrforum
05-08-2006 06:43 PM
muffinman
03-27-2006 10:34 PM
muffinman
03-27-2006 10:29 PM
madsn11
12-10-2005 08:13 PM
Quick Reply: Installing frame sliders
