Headlights aren't working- HELP
Does the bike run? If not probably your headlight harness by the left air intake. If so then its probably your starter button not coming all the way out. When you push the starter it cuts out the headlight to give the most power to crank the bike then once running and the button is released the headlights should come back on. You also might have to take apart the starter switch to make sure a solder connection didn't come lose.
Well im having the same problem as we speak. I have changed out the front harness and the rear harness because my lights dont work the high beam light wont go off the fuel pump is not coming on. It still cranks but no spark everthing else is working besides that. Talked to a friend of mine at MMI and they told me its a broken ground some were in the main harness. Yesturday i was messing with the computer moving it around and the pump came on and it was working again. Thought i had it fixed so put it back together and nothing i think its the plugs coming from the computer theres a broke wire leading out of it, so im waiting on the new harness. Thats all thats left to fix. Ill let ya know if it works.
check this thread
https://cbrforum.com/forum/f4i-main-forum-11/headlights-dont-work-112649/
Most likley bad wiring in the starter switch box.
Will Blanton
02-02-2021 01:03 PM
