FI light blinks 2 times
Hello everybody!
It is my first post on this forum. I'm glad i can find so many CBR enthusiasts in one place.
I'm sorry that my first post is about an problem i have encountered and not about something more pleasant.
Yesterday i have changed the spark plugs and the air filter on my CBR 600 F4i (2001). I have put an NGK IMR9C-9H spark plugs and an K&N HA-6001 air filter.
The problem is that after this changes the FI light flashes 2 times when the bike is started and is in idle. When i rev up the engine the FI led remain on.
The mechanic that changhed the air filter told me that he thinks the FI flashes because i have put an sport air filter and i have an stock exaust.
I'm not so sure that his could be the problem. I have read the service manual and i have found that 2 blinks of the FI led signifies :
"Loose or poor connection of the MAP sensor vacuum hose" or "Faulty MAP sensor"
Togheter with him we had verified the conection of the MAP sensor and it seems ok.
I wanted to ask you if endeed the air filter can be the problem in this case ?
Thank you very much !
Thank's for the ideea !
i had this problem after i installed a manual ape cct on my f4i. i had taken the air filter box and throttle bodies off to get to it better. and what i did to fix everything was just made sure all the hoses where in the right place and not crossed, and make sure you connection to your map sensor is good. and after that my light went away, turns out i forgot to connect one little hose to my air box.
