FI light? 2 blinks
Old 06-07-2009, 08:57 PM
kup125's Avatar
Default FI light? 2 blinks
so my FI light came on today when i was riding...when the the key is on it blinks twice. does anyone know what this code is?
thanks
Old 06-07-2009, 10:31 PM
Elfling's Avatar
Ladies Lounge Moderator
According to the service manual, 2 blinks at ignition is faulty MAP sensor and/or loose connection of the MAP sensor hose.
However, check the length of the blinks- a 1.3 second blink is equal to 10 blinks which would give it a different code. If they're both the same length and a fast blink, then it's just what I typed above from the manual.
Old 06-08-2009, 01:08 PM
FLYOU's Avatar
yep map sensor.
check the vacuum hose and make sure she's snug. dielectric grease the pins to help increase electrical conductivity.
Old 06-08-2009, 07:55 PM
mbison83's Avatar
had the same problem. i took the tank off and noticed the thin hose was disconnected from the MAP sensor. hooked it up, turned my f4i back on and the light disappeared.
Old 06-08-2009, 08:51 PM
kup125's Avatar
great thanks ill check it out
Old 08-26-2023, 09:08 PM
phia_thao's Avatar
Where is the Map sensor located? I have a 2008 600RR with this FI error. Any help on location would be great!
Originally Posted by FLYOU
yep map sensor.
Attachment 62633
Old 08-28-2023, 09:01 AM
Scott91370's Avatar
You'll get better response by heading over to the 600RR section of the forum. An easy mis-click may have put you here in the 600F4i section.
Old 09-01-2023, 12:26 PM
dannoxyz's Avatar
Error is for "MAP sensor circuit", not map-sensor itself. CIRCUIT includes:
- reference 5v power supply wire
- ground wire
- signal wire to ECU
- vacuum hose
- MAP sensor itself
Manual has procedure on testing all of these along with measurement standards. Most of time, it's vacuum-hose that got knocked loose or connector was unplugged when removing/installing petrol tank. Identify actual cause of problem through measuring and testing first.
Almymichael
05-08-2017 07:43 AM
kneepuck
09-01-2011 02:33 PM
SN952NV
02-27-2011 07:36 PM
xds949
02-18-2007 09:51 PM
PegCBRF4i
04-22-2006 01:27 PM
Quick Reply: FI light? 2 blinks
