F4i hazard lights...
Old 09-06-2010, 12:59 AM
John Cu's Avatar
Default F4i hazard lights...
Hi folks.
So i want to have hazard lights on my f4i but i dont know how to do it, anyone knows how??
I guess it could be easy but i just don't know how?
Old 09-06-2010, 12:05 PM
iMac's Avatar
^^ x2 been wondering about this for a while.
Old 09-07-2010, 07:26 AM
Xander F4i's Avatar
I know a Guy that has some wired on his zx-9r...I've been meaning to ask him so I can do it on my bike
Old 09-07-2010, 07:47 AM
Michelle's Avatar
Kawasakis are easy. Just swap the switchblock for one off a bike with hazards. We did both ours.
What Honda has hazards as standard?
Old 09-07-2010, 09:04 AM
Xander F4i's Avatar
i googled it and this result came up... http://ybriders.multiply.com/journal..._Hazard_Lights
the guy i know has his on a separate switch like the link i posted here would produce...i'm just not sure i like the looks of the install from that link
Old 09-07-2010, 10:03 AM
Michelle's Avatar
Waaaay too much effort! I think you should be looking at say, CBR1000RR?
When I did my Kawasaki it was a plug n play. It uses all the standard wiring and flasher unit. The only reason I haven't done my 1000F is because I need one that has the choke lever.
Maybe I'll use the Kwaka one an just swap both switchblocks.
Old 09-07-2010, 11:07 AM
Xander F4i's Avatar
http://www.motorcycleproject.com/mot...t/hazards.html
here is another option...it explains two methods. one like the above link (method 2) and one re-purposing the kill switch. though i'm not sure if the bike would run if you used the kill switch...if it would i think it would look cleaner...can anyone confirm, that the bike can be made to run without the kill switch, for me?? i can live without my kill switch...i normally use my key or the kickstand to stop the engine anyways
Old 09-07-2010, 07:41 PM
Zero1080's Avatar
^If you can bypass it, it can. Take apart your switches, and you basically have to find a way to permanently trip it. I wouldn't recommend it at all honestly.
Just mount a new, simple switch somewhere else. I know the arm signals, so I'll do that if I have to pull over.
Old 09-08-2010, 10:39 AM
John Cu's Avatar
It looks good to me, maybe i'll try this one., but, i dont know if it will be easy doing it on the f4i...
Btw of course i'll put the switch in another place, maybe on the air duct cover like the one i already have for the radiator fan...
Old 09-08-2010, 01:44 PM
gump's Avatar
I kind of always wanted a white strobe that would stay on all the time. I know its cheesy but if a strobe light can get the attention of a soccer mom on her phone sign me up.
Quick Reply: F4i hazard lights...
