DIY valve timing adjustments? - CBR Forum - Enthusiast forums for Honda CBR Owners
Thread Tools Search this Thread
Old 03-08-2009, 08:47 PM
Default DIY valve timing adjustments?
Its time for me to get my valve timing adjustment checked, get the CCTL changed, flush the brake lines/fluids, install a new chain/sprockets and rear tire. I knew it was going to be expensive so I wasn't surprised by the prices I got back but I want to tackle what I can by myself to save money and learn more about my bike.
The sprockets, chain and tire will be done by a shop, I don't feel comfortable doing alignment/tire balancing, plus I don't have a chain breaker/riveter.
I know there are a few of you who have tackled valve timing adjustment and CCTL's, was is something you could handle with a walk through? I am somewhat mechanically inclined, I may not know every part but I can figure things out quickly with a manual. I know that they are both time consuming, but how technical are they? I assume the CCTL is fairly straight forward once you get the case cover off and actually get to it, I however don't have any insight on valve timing.
If you have any advice, tips or guides that you found helpful with either of these, please post them or PM to me. I can save myself about $500 doing the work myself.
Old 03-08-2009, 09:57 PM
you won't have to actually take your bike out of time to check your valve clearance, only if you actually have to replace shims to change the clearance back to spec
what i'd do is get down to and remove your valve cover, and then you can rotate the motor with the timing hole on the right side, just turn the motor over so that you can check each vavle's clearance against the manual
generally unless your bike has been sluggish lately you won't have to swap out shims.
then, push down on the cam chain in between the camshaft sprockets while you remove the CCT. this will keep the loose chain from jumping any teeth so you won't go out of time. then replace the tensioner with a manually adjustable unit and reassemble your bike.
if you do need to replace shims, you'll have to take the cams out to get to the buckets. look in your service manual for details about this bc it's a little more indepth than i'd like to go into on a post.
if that's the case just email me at bwayers2006@yahoo.com and i'll talk ya through it.
Old 03-09-2009, 03:59 AM
Sweet, appreciate the help offered! I wont be starting on this till the end of this month, i want to wait for my tax return and do it all at once.
Old 04-18-2009, 09:36 AM
j4eric's Avatar
Default valve adjustment f4I
Old 04-18-2009, 11:15 AM
DFour's Avatar
j4eric... great find man. good work.
Thread Thread Starter Forum Replies Last Post
Is it worth the $$ to have valve adjustments? ROOKIE 09 F4i - Main Forum 14 03-24-2011 12:57 PM
Valve Clearance adjustments Snyds67 General Tech 2 07-04-2009 05:53 PM
Valve adjustments jacobsdr CBR 600F2 11 08-08-2006 07:05 PM
Valve Adjustments Nova Scotia Mike CBR 1000F "Hurricane" 8 05-14-2006 11:44 PM
time for valve adjustments a56kuser F4i - Main Forum 6 11-14-2005 02:26 PM
Tags
adjust, adjusting, adjustment, adjustments, barf, cap, cbr, cbr600, cbr600f4i, diy, f4, f4i, hole, timing, valve
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
