Cylinders 1 & 2 run, 3 & 4 are dead.
I would check the plugs again. They may be saturated with fuel on them. On top of it did you get the right plugs? How freely does the motor spin when cranking it? Also did you check the resistance of the coils? Did you ohm every injector out? Did you check fuel pressure at all? Maybe a skipped a tooth on the timing? Do you still have the stock timing tensor or oem. Next time use spark notes so faster to read
I agree that it sounds like it could be a fuel problem but its very possible that a head gasket could be an issue. The symptoms are right. And those are simple tests to check on the condition of your engine anyway
The fuel was not old when the problem occurred but then again, here in Sicily, the fuel is not the best like in the states. Lots of people here complain about the fuel. What would be the best adative for my fuel?
I took my bike out yesterday and was very excited, no loss of power, no missing cylinders and started just fine. Also, anyone have any recommendations for a replacement exhaust? I know, everyone has their own opinion but there has to be a trend for what works best with the F4i?
Fixed
Well, I am going on about a month now with no problems at all. Its crazy but I read on another thread about someone running the starter with the throttle all the way open for about 5 seconds at a time. Let it sit for a min. and then do it again. Do this 5 times and then try to start the bike normally. The engine was cold when I did it. When I finally tried to start it, it took right off. I haven't had a problem since. Could have been the gas, it could have been a wet cylinder. Who knows really but all 4 are running. Thanks for all the advice.
This is what worked for me.
I followed the instructions to the T, cold engine, throttle wide open, crank for 5 seconds, wait 60 seconds, repeat 4 more times.
Good luck
Good luck
WhiteHawk
05-30-2013 09:56 PM
