CBR600f uneven jumpy idle
coils usually die at high RPM .. so wouldnt think its that .... try this... start the bike from dead cold, and leave to idle with the lumpy business... now touch each header and see if they all feel the same temp (or use an IR temp sensor if u have one) .. if some are a lot colder compared to the others then u can use this as a big clue to whats happening and where to focus on the troubleshooting.
I took those temps after the bike has run for a minute
According to my manual John those MIL codes are as follows.
The 1 blink=
Loose or poor contacts on MAP sensor connector.
Open or short circuit in MAP sensor wire.
Faulty MAP Sensor
The 9 Blinks=
Loose or poor contact on the IAT sensor
open or short circuit on IAT sensor wire.
These are from the Clymer manual page 323-324. let me know if I can help with anything else.
The 1 blink=
Faulty MAP Sensor
The 9 Blinks=
The 1 blink=
Faulty MAP Sensor
The 9 Blinks=
The 1 blink=
Faulty MAP Sensor
The 9 Blinks=
This would explain my issues. IAT sensor would adjust the speed of the engine based on temperature so if that's faulty it would cause erratic idle and map sensor is responsible to tell the computer how much fuel to inject based on air. I have found to how to clear the codes which I have done now, will ride for a day or two and see if the codes come back, if they do I will inspect those sensors!!!
Thank you
