Adjusting Clutch Cable
Ok I'm looking through the manual and i'm doing everything it says and i'm completely stumped. I think where I went wrong is where the cable goes through from the clutch cover to the lever. When I steer left the clutch cable will get really tight, if i steer right it will get really loose. What am I doing wrong here?
RE: Adjusting Clutch Cable
Ok i've pretty much tried everything, moving the cable in every possible place and adjusting the two bolts by the clutch cover and i just can't get anything going my way. I think i need step by step instructions and pictures sadly because i don't know what it's supposed to look like anymore. if someone has a picture of their right fairing off exposing the configuration of the clutch cable that would be really helpful. thanks.
I can't figure out any other way to route it? Pictures of one that is properly routed would definitely help. This is a new cable i'm replacing because my old one snapped in half. I got the silver compression part to go in a little better but still not completely in. I rode it the way it is and i'm getting way too much free play, probably like 30-35mm.
You need to adjust your clutch cable at the crankcase, turn the adjustment outward from the casing so that you take up all that slack in the cable. If you have the crank case side adjuster all the way out (except for at least 3 complete threads engaged) and you have your clutch perch adjuster all the way out (again, sparing 3 fully engaged threads), and there's still slack? Then you need to investigate your clutch plate thicknesses and your clutch spring lengths to see if they're beyond critical limits.
Do you have the factory manual in PDF form? It's a godsend.
the blonde weasel
the blonde weasel
Zandaloo
08-22-2013 03:26 PM
