lowering link or stock link
Old 04-03-2006, 10:46 PM
delta's Avatar
Default lowering link or stock link
I have an 04' f4i that has been lowered with a lowering link (the bolt is in the upper hole, so its at the 3 in. spot correct?(there are
only 2 bolt holes to use)). According to a local shop it needs to be at stock height to pass inspection.
Question is what years and from which bikes can a stock link be used on my bike?
I hope this makes sense. If this is the case, i have less than 30 days left on my temp. registration. So
i need to get this taken care of ASAP!!
thanks for the help.
Old 04-04-2006, 06:36 AM
Default RE: lowering link or stock link
I have a lowering link that has another bolt hole to put it back to stock size
Old 04-04-2006, 01:20 PM
delta's Avatar
what i want to do is raise the bike up to the other bolt hole (1 inch below stock) and
take it to inspection and see if they don't notice. I just don't know how to do it. Do i
need a rear stand? I have a 2 ton car jack and a jack from my car. Can one person
do it by themselves? Where do i put the jack at? Can someone explain how to do this,
I have no idea how.
If this doesn't work, how much for the link?
thanks
Old 04-04-2006, 02:16 PM
what inspection are you going to?
Old 04-04-2006, 03:27 PM
delta's Avatar
md state inspection.
im 99% sure its required when anybody buys a used car/motorcycle
from a private seller.
foxens
05-14-2012 08:24 AM
Morayman
01-21-2009 11:36 AM
djblaze247
09-08-2008 11:09 AM
Quick Reply: lowering link or stock link
