Valve shims
Old 06-02-2012, 02:31 PM
swaskowiak's Avatar
Default Valve shims
Well, long story short, I had to change the head on my bike. I used a head with good valves that seal properly. It did not come with valve caps and shims. I put the cams in with my old caps a shims and discovered that I had little to negative lash on several valves. I am wondering if anyone has sujestions how to make it easy to figure out what size of shims I need to order for the valves that have negitive lash? I have ordered the hot cams shim kit and am trying to avoid a trial and error process of bolting and unbolting the cams.
Old 06-02-2012, 06:29 PM
MadHattr059's Avatar
Find the thinnest shims you have and go through each one by hand and use them to try to get some sort of
measurable gap. Bit of a PITA, but that's the best I can come up with. ;-)
Good luck, Ern
Old 06-02-2012, 11:31 PM
swaskowiak's Avatar
Thank man. Ha that's what I figured I would have to do looks like I have some fun times ahead of me
Old 06-03-2012, 07:59 AM
If you wait for the shim kit, you can put the smallest ones you have in the worst valves.
Then the second smallest, etc. Re-install the cams and hopefully that will give you
enough gap to measure and determine what you really need. I just don't see
anything else working, without doing the job twice.
Ern
Conrice
07-18-2012 10:13 AM
mark1200
03-02-2011 01:12 PM
oldschoolsdime92
10-31-2008 11:00 PM
axsys
05-04-2008 05:40 PM
jalate compa
11-14-2007 08:55 PM
Quick Reply: Valve shims
