No vacuum line on gas tank
Old 03-09-2013, 09:18 PM
JNSRacing's Avatar
Welcome Crew and ROTY 2014
Originally Posted by optytrex
OK, so upon replacing some of the older hoses that ran from the gas tank to the bike I found that several of them were in fact kind of cracked around the edges and decided to replace the ones that are like that. Which is more than I had hoped. One of them was even missing a bracket-like pin that holds it in place (although that didn't seem to affect anything in particular in regards to the leak).
But I did catch the Petcock leaking red handed. But not from where I thought...it was near the handle *and* where the insides are; so I'll probably end up replacing the whole thing if I can't fix the issue--but since I didn't get around to checking and cleaning the Float Valve I'll decide afterwards.
Crap! I responded to the other posts, before I read this last one!
There are re-build kits out there, by the way, for the petcock - much cheaper than replacement.
  #22
Old 03-13-2013, 06:51 PM
optytrex's Avatar
Hahaha no problem man I'm waiting on the arrival -- I was looking at where the leak is from and noticed that it actually leaks from the lever and from the petcock valve so I decided to buy the petcock valve and the lever new separately for about $20 each, the repair kit is almost $40 on it's own and I figure it saves me the trouble of actually fixing the issue.
JLAvila
06-08-2013 02:34 AM
Deilke6
03-31-2013 09:38 AM
CBRnoobie
10-14-2010 06:16 PM
CBRnoobie
10-11-2010 01:20 PM
DECwakeboarder
03-28-2007 03:56 AM
Quick Reply: No vacuum line on gas tank
