Just bot a F2 1992 for cheep
Generally weak points are Reg/Rec, it'll show up as charging issues - hard to start, you'll keep getting dead batteries. Also the cam chain tensioner is knowing for wear, resulting in cam chain noise.
Other than that I'd take a look at brakes, tires, suspension for leaks and or squeaks at the rear, worn or leaking fork seals at the front. I'd check the steering head bearings for noise - they will creak and or start binding if very worn - not what you want but it can be fixed. Check coolant color and condition, cooling fan operation, does the gauge work does it over heat? Check oil level, color and condition. If you can compression and leakdown test will tell you how the engine is. Generally these are pretty tough - My F2 has 61,000 miles and it is fantastic, runs and rides smooth - that said it needs a clutch and a fuel tap rebuild, I have parts coming for it.
I would suggest a full service on a machine with unknown history - replace oil and fuel filters, air filter if its due/dirty, change the oil, flush cooling system, new thermostat. Additionally valve clearance check, go over the carbs, and synchronise if you wish, if its running nice I wouldn't worry doing it asap. This way you know what is done when, and you'll have a reliable smooth running machine. A shop manual is valuable but you can find service info on here.
FYI, you can't really tell the condition of the coolant by looks, unless it's so gummed up with rust or oil that its condition is obvious. Again, with aluminum engines, you do NOT want to **** around with crappy coolant, as the properties that make it safe for aluminum engines and protect from electrolysis (the latter being something that few seem to understand the importance of) will wear out long before you see anything by noting the color of the fluid. If the age of the coolant is unknown, it's way past time for a flush and fill.
Been working on liquid cooled aluminum engines since the mid-70's, and I have lots of horror stories. I'll spare ya that here and simply state that this advice is ignored at your peril. A couple of hours and less than $50 will save you untold grief and hundreds of $$ down the road.
