I need F2 carb help
I dont know what the top pic is supposed to be other than its not factory. The bottom pic, the smaller ones between 1&2 carbs and 3&4 carbs are breathers and dont connect to nothing. The big one between 2&3 carbs is also a breather that supposed to connects to the bottom of the air box small filter thing about the size of a matchbox. The rest of it I'm not sure since it looks like a custom job to say the least. Also the big one to the right of carb#4 between the coil and frame is the crankcase breather. Go to an online OEM supplier like Ron Ayer or cheapcyleparts and look at the schematics/diagrams, that should help.
The four small ones were the ones I was concerned about. I didn't know where they originally went. The top picture is merely a close up of the four hoses and how they have them ran into the bigger one that was crammed between the carbs. Hose was almost clamped into in that tight space. I will look for a diagram thanks.
