Carburetor Cleaning & Tuning 101
Old 05-04-2015, 09:45 PM
Existenz_is's Avatar
Originally Posted by johnnyx
I just wanted to say I can't believe this thread is still going. You guys are awesome.
I sent Dissevered the pics of when I redid my carbs, but he never posted them up.
  #292
Old 08-27-2015, 03:54 PM
optytrex's Avatar
I took tons of pictures when I took mine apart for a good cleaning so that I wouldn't forget the order or locations of things. If anyone wants them I have them.
  #293
Old 04-30-2016, 09:48 PM
solidsnake808's Avatar
i wish the pics were still here!
  #294
Old 03-28-2017, 01:42 PM
danroonie's Avatar
Pictures would be nice
  #295
Old 08-09-2017, 02:34 PM
stejoh123's Avatar
Default Carb Tuning CBR600F2
I saved the original posting with pictures. doc file attached
File Type: doc
  #296
Old 09-13-2017, 01:05 AM
cs48zar's Avatar
Hello everybody,
I've been working with a colleague of mine on his CBR 600 F2 from 1991.
We have done the following:
Found out that compression is low P1 8.5bar, P2 8 bar, P3 8 bar, P4 7.5. We have checked the valve clearances and adjusted accordingly. We then remeasured and got 14.5, 13.5, 14, 13 bars. We managed to hit the sweet spot with the valve clearance adjustment.
We then proceded to change the oil, oil filter and clean out the carbs.
Pilot jets are 38s while the main jets are 132. We found out that in the vacuum sliders the needle had a shim under it under all 4 carbs. We took it out suspecting it is a aftermarket mod (please could someone confirm if this comes stock out of factory with shim under needle or not!?).
Bike has K&N sport air filter and a slip on can from Sebring.
We then put the darn sync tools on the carbs. Managed to get equal values on all 4.
Last step was to adjust mixture screw as per manual description. Bike runs fine but when it gets to around over 90 degrees until the fan hits it idles fine but then dies.
We put voltmeter and shows a consisten 12.9V. Regulator is brand new. Cranks the bike and doesn't start. Cranks again open a lil bit the throttle and then starts. Is this normal?
With a weak battery there will be no chance to start it....
Can someone give some feedback if we did miss something.
Here is a video about how the carb sync went.
Also please subscribe to my youtube channel Many thanks to all of you.
  #297
Old 08-01-2018, 06:16 PM
easyrider23's Avatar
Hey Guys...awesome write up on carb cleaning. One question do i have too remove
the the pilot jet in the bottom of carb for the D-shaped wrench id rather leave it at spec setting..
bike ran great... sat a few months. Starts rite up but dies if i snap the throttle after warm. Thanks!
  #298
Old 08-03-2018, 11:16 AM
tentacleslap's Avatar
The solution is to count the turns until the pilot screw seats. Write it down, then remove for cleaning. Then it's just a matter of reinstalling it, lightly seating it, and turning it back out the correct number of turns
Hope that helps
  #299
Old 08-03-2018, 05:30 PM
Rite on! Thanks!
  #300
Old 08-04-2018, 08:18 AM
Phil314's Avatar
Unfortunately, when carbs get plugged up, it's usually the small passages that get plugged.
The pilot screw (which affects idle) is a small passage. It's the most common one to get plugged.
So yeah, you need to clean it to fix your problem.
Just do what Tentacleslap said.
Quick Reply: Carburetor Cleaning & Tuning 101
