vfr800 to cbr954 front wheel swap ??
ok motor heads has any one done a vfr800 wheel swap on a 954 ??
been looking for a rc51 sp1 wheel with no luck so I've found several vfr800
rims for sale ????? its the correct size of 3.5 x 17 so ...........
please any help is greatly needed!!!!!
Keep it on two wheels my fire blade brothers !!!
You need to know 3 things:
- Axle Size
- Hub Width
- Rotor bolt patter (to see if you could mount 954 rotors)
Find out those dimensions plus the 954 dimensions and we could easily figure it out.
Bolt pattern, offset and center hole are different size on the discs.
I usually check them here BRAKING | Power Under Control
