turn signal issue
turn signal issue
So i went through inspection today. and i was failed using the same setup that i used 2 yrs ago through inspection. they said that my turn signals were blinking too fast and r supposed to be in 1 sec intervals. so i called a local shop asking what to do. they said get a relay switch. so i bought one at there shop for $28 only to find out when i got home and looked that the product online that it doesnt work for the 954. its a rumbleconcept.com honda led easy plug relay. so im going to go return this tomorrow. should i just buy non LED signals would that fix it? ive seen stuff online saying you can plug one of these relays into the 954 but i dont even know where the stock relay is on the bike. if anyone can help id appreciate it. thanks
Get the relay from: model FLFS-1-FLAT
LED Lights, Bulbs & Accessories - SUPER BRIGHT LEDS
LED Flasher Unit LF1-S-FLAT Specifications
Your relay is located behind the headlight.....signal & listen for the clicking sound. Thats your OEM,
the FS-1-FLAT relay do not make any sound. But it's should plug right in....to be sure, you can pull your OEM out first and check connector....don't buy from ebay @ $26...
get it from Superbright for $11, or kneedragger for $13
Ok, here it is...I found the direct link:
Super Bright LEDs - Electronic LED Flashers Specifications
look at the bottom, the second one.
#LF1-S-FLAT
your OEM relay is 3 pin - across....most HONDA & YAMAHA is same.
pull your OEM and look at it....
I order this one from Superbrightled on Friday, and package showed on Monday!!!
It fits my 94' CBR 900RR , and it also fits a members here with s 1000RR.....so likely it will fit your 954.
Should take 2 minutes to install
#LF1-S-FLAT
#LF1-S-FLAT
#LF1-S-FLAT
I did buy these led lights to front and these resistors.
I did try those lights and resistors to accessory 12V battery. They worked.
Then same thing to bike, no blinking at all.
I did noticed that turn signal light in the screen is blinking normal speed but when I taked the led light off then screen signal light flashed twice as fast than normally.
Like when you have a broken bulb then signal light flash faster.
So I did install lights right but need that relay and that`s why led lights didn`t blink ?
I have to buy that same relay, but isn`t orginal relay integrated some where ?
So if I buy that reley how I connect that ?
Here's the link if you want running lights
https://cbrforum.com/forum/how-mecha...-84998/page14/
But one thing I must mention is that if you go all led, meaning front & rear...then you indicator may blink dim. That's what happen to me, so I need to replace a led bulb for the indicator on cluster.
Turn signal relay is really integrated in the instrument cluster so it`s not just plug and play thing.
If I want led signal work I have to cut two wires somewhere and plug that new relay to those two wires.
Dam this is hard .
Lucky you, you can just take old relay out and put new relay there
If I get those led lights work I will post here how I done it !
