TooBroke rebuild 954 thread
#21
Powder coating it white to match the fairing. Pita to get it out though, little update finally got a garage to work in. I have been working out of my neighbors but he only had one spot so I rented the space next to his. Hopefully this week I'll have time to get my engine hoist from my brothers to build this bad boy.
#24
#27
#28
To be honest my results look exactly like post #14 from the thread below:
Anyone using Plasti-dip????
I can post pictures if you would like but it is just my subframe, I am not doing the frame or anything else until I get a little bit more into the build. I am happy with the results though and it does look good and should hold up okayish.
#29
Update I tore the bike apart last couple dats . couple things the swing arm was dented so I popped that out and will weld a new spool mount. The other thing is the beating for the shock mount seems to be frozen. I'm not sure how important that little bearing is but I'll probably just replace it. Tore all the pegs apart and cleaned them a bit also picked up some caliper pint for the rotor centers. Contacted a different vendor about PC the other guy doesn't return phone calls.
