TooBroke rebuild 954 thread
Hey no problem we are all in this together. I am definitely going this route until winter and I really don't think it will rub off the way you think. The guy who did his swingarm has had no problems. And also at $6 a can you really cant beat it for a temporary solution. I am doing my frame, subframe, and swingarm in plasti dip. I will then be doing my side covers and triples and some other misc parts in duplicolor high heat. And doing my rearsets and passenger sets in duplicolor high build fleet paint. It holds up real good and will not rub or flake off like plasti dip or the high heat.
Or maybe $30 in plasti-dip.
Hmm......
I believe we are both seeing the plastidip as a non permanent solution until we can save up for the PC'ing at least that is how I feel about it. I actually bought a couple cans tonight so I am going to do this soon. I think I am going to put the frame, subframe, and swing arm together and plastidip it all at the same time instead of doing it individually. Plus I am really only going to do the noticable areas. There is no reason coating everything when it wont even be seen.
Or $300-400 in paint and $600 in PC'ng....
This is the fairing kit I ordered from auctmart. I have to paint the tank anyway and buy the correct decals. My other problem is I Dont know what set of decals that would be. As far as updates I had about an hour or two to get the spring removed from the rear shock Friday before I had to run two calls. Thanks for the input guys.
For sure the quality is better. As for the color on the rims/calipers - white is going to be a pain to clean on the rims with the rotors on. Are the colors of the bike going to be only black and white?
Exactly - I just don't want to wait until I have the money to PC in order to be able to ride it. I've even thought about just bed lining the tank and fairings for the time being too. That's another $15.... and I'd be set....
Nice fairing choice Broke. What's going on with the shock?
