TooBroke rebuild 954 thread
#121
It worked really well but it sort of shattered after I used it not sure if it was from the brake cleaner, brake fluid, or just the force exserted on the plastic. Should work well for you.
#123
You can use the meat injector to draw fluid out as well If you like.
#124
#127
But it's really easy to test. Delete it and see if it fixes the issue. Also make sure that the connections (the ground) are good on it.
Why do you ask, what do you suspect is wrong?
#128
Meh I'll just leave it the way it is and let it be someone elses problem. If that the worst thing on the this bike im ahead.
#129
Try zero map. It should work as stock. If it doesn't there is something wrong with the commander or connections. If the zero map works the maps you tried are just of.
#130
My wife literally just picked up the tank from the shop and sent me a pic. Thought i would share.
