modify frame cbr 954
#22
#23
#24
Marco, take pic of your bike from a similar angle. All they've done is weld a triangular block to the bottom part of the frame. There are 3 bolts holding that piece of billet to the frame. Then it bolts to the motor mount via 3 more bolts. I'd suspect that its fairly thick and that they drilled and tapped those tabs to improve on the feeling as much as possible. The motor mount is hollow. Its possible that they welded on a plate to give a flat surface and enough material to tap.
I was looking at my bike, and I'm going to guess the rearsets needed to be shimmed out.
But its a really simple concept that you could achieve through your own simple design.
If you are interested in the look of it, your only option is to get a CAD file from Erion. Even then, a machinist would be able to put some of those accents in it by looking at pictures of that one.
#25
#26
This concept of bracing the swingarm mount to the frame Intrigues me for a project I've been thinking about..
#28
If you just wanna see how it'd work get yourself a touch some flat steel and a marker. Cut the steel to an appropriate size to fit the space mark where your want the crease and holes heat it up bend and you have your self a relatively cheap prototype. Than just find a welder and youll be on your way.
I'm honestly thinking trying this in the summer but just to make motor mount points for a 1000.everyone says its impossible but if you have determination and a junk bike y not?
#29
#30
