Mika_U's 980CC Build
#61
Did you have a wrecked 954 tank. Maybe you could cut the bottom out of it and use that as an adapter.
#62
I doubt it has anything to do with the airbox size or velocity stacks. I had Factory Pro velocity stacks and we checked them against the stock velocity stacks on the dyno and there was absolutely no difference in power so I sold them to someone in France. If so I should have seen a problem when I installed nitrous on my 954. Even putting the nitrous spraybar, showerhead and lines between them into the airbox which seems to take up quite a bit of room did not affect the motor tune at all.
My 954 at stock wheelbase after tuning made 146.5HP / 71 Torque. When I went back to have my nitrous setup tuned stretched about 8" my baseline numbers dropped to 138/68 which was expected. After nitrous tuning at a safe 12AFR my bike made 178HP / 91 Torque or 186.5/94 at stock wheelbase on a bone stock engine. I have been spraying my bike for nearly a year now with this setup at the dragstrip with no problems.
#63
#64
It could allso be the exhaust or tb:s restricting it but i'll get to bottom of it when the riding season ends. I just really don't have the skills or time to measure all the facts of the cams, head (tract lengths, volumes etc.) to see what could make a difference to it. And i'll get the head flowed by another guy to see does it really flow enough or is it the head that is the problem.
#65
Not to mention your valve timing, Mika. And when the tuner mentioned the original rich AFR you had above 12k, it seems to me that air flow stalled. With the timing, the curve should have climbed through 13k.
I'm sure that the intake runners are the right size for a 954 engine that only revs to stock RPMs, but Mika is revving much above that, which changes things. On my 1000rr airbox, the velocity stacks are much shorter, and the airbox is taller to (to which degree that is because of the secondary injectors - I don't know).
#66
Haha.
Seriously though, have you talked to someone who knows how to measure the intake charge that happens past BDC? That's what I'd be curious to know before I started taking off more material or contemplated bigger valves, etc.
#67
That's a good point as well - the beemer screamer (S1000r) has 48mm TBs specifically because of how high it revs :hint hint (do it!):
Haha.
Haha.
The program tells the intake charges at different revolutions (VE) and really lets you change everything and predicts the outcome.
We will first measure the intake side (air boxes, stacks etc), valve timing and then take the head of and flow the head before making any changes to it. And probably measure the real compression ratio instead of trusting what it says in the pistons box. No more of putting parts together and hoping it works. Somebody that really knows what counts can do the final adjustments and changes to it. The bottom end stays whole. Not planning on doing anything to it or the frame. Everyhing is new or serviced so no need even for that. Only thing actually missing from the bike is my crash bars. I haven't had the time to pick them up from a friend that made them and i have to paint them when i get them.
#69
#70
