Check Out my video on how to check fuses are good.
How to Check fuses are good with powerprobe3 - YouTube
I do believe the yellow 20amp fuse in the center will have ground at both ends even though it is blown. If your headlights dont turn on with key switch on, then use pp3 to check for power at both ends of that fuse, if not, then it is blown
When I said switch, I meant to say circuit breaker. Im going to fully script the scenes in the future. I got some really HOT girls to do some intros to my videos, for the fellas out there. Ill take request in the future, if its reasonable. Show me some love people; Im trying to help others while eventually helping myself. Next up is how to calculate the new shim size using the old shim and the measured clearance.
I got mine from a Mac Truck at a Drag race. You can get it cheaper online though. Theres a lot more you can do with it than what I showed. Ill have to show other functions later.
Ya, a lot of people think it is a test light, but if you use a testlight on some newer vehicles, you can set off the airbag, or short circuit the sensitive computers. I also used this device to check the maximum output when checking the CKP; the manual for my bike calls for the use of a "special tool" to record max output, but this does same thing. No more jumper wires for me.
