Cbr 954 spare ecu
Mine does. Flashing is a modern tool to remove or change things that have been put on a bike built in the modern age. The 954 doesn't have secondary butterflies, a top speed limiter or other criteria for flashing. Power commander is all you need.
What do you think i need? I can tell you i need little more then the power commander can do. Tuners that flash ecus normally just use the software. Your telling me your tuner developed the software he uses to flash ecus? I kind of doubt that. And your knowledge of what can be done by flashing or what it is falls little short.
Ditch, he needs another 1500 RPMs,the ability to run different TBs, really advanced ignition timing, etc.
Mika has done a TON of work to his engine and is looking for more. The guys that helped build his engine are well known Finnish drag racers.
For example - I'm looking for more than a power commander too. I'm looking for an HRC ECU (one for a 1000rr to put on my 954). Granted I'm running 08 1000rr TBs... But I've settled on those. I think Mika wants to experiment and try to find the best setup...
