Put on a new gas tank ... went to start the bike ... and it shut off
Old 09-06-2011, 11:33 PM
Robles929's Avatar
Default Put on a new gas tank ... went to start the bike ... and it shut off
now it wont even turn on AT ALL.
I made sure all the hoses were connected properly as well as the little connector that goes into the air box right by the gas tank. It's all connected properly.
Fuse box checks out, no fuses blown. I'm not very good at electrical stuff but I might become well versed with the proper direction. First thing I'd need to get is one of those meters?
Then where should I start the diagnostics??
I turn the key and have no power. Battery is not drained. I've hooked it up to a tender and it check out A-OK.
Old 09-12-2011, 12:50 PM
smoorebmw's Avatar
did you check the main fuse?? On my 954rr there is another fuse that is not in the main fuse box...hope it is...
Old 09-12-2011, 06:23 PM
MadHattr059's Avatar
If it's like the f3, there is a 30amp main fuse, piggy-back with the starter relay.
Look under the seat, forward of the battery compartment. That's the first place to start.
As far as why it blew the main fuse, pull the tank and look for any wires that you
may have in-advertantly pinched/frayed when you did the swap.
Not much use changing the fuse till you find the short. Before you run out to
buy a multi-meter, try the Mark I eyeballs first. Follow all of the wires from the
battery, looking for cuts/nicks/burnt/melted spots. Odds are you'll find the
problem that way.
good luck, check back in, if that doesn't help, Ern
Old 09-12-2011, 10:54 PM
stealthCBR929's Avatar
Official Glory Detailer
get a work shop manual they have wireing diagrams check fuses relays if there good chances are you have a broken wire the work shop manual is the most important period i do ac and electrical work ford motor corp with out my books i would be screwed especially for pin point tests lol
Old 09-13-2011, 03:13 PM
Robles929's Avatar
thank you for all the replies. I will try to get to it this weekend and see how it goes. I had no idea about that other main fuse not located in the fuse box. I'll start from there and start tracing wires and such ...
I hate taking the gas tank off ... I waste so much gas,
And I have the shop manual ... I wouldnt even have gotten the tank OFF without it, lol
jblair626
03-22-2014 02:25 PM
johnk16
03-22-2014 09:16 AM
NoRider
08-14-2008 01:45 PM
Hatred
04-05-2006 02:25 AM
Quick Reply: Put on a new gas tank ... went to start the bike ... and it shut off
