Need help bike wont start 2001 929re - CBR Forum - Enthusiast forums for Honda CBR Owners
LinkBack Thread Tools Search this Thread
Old 11-13-2010, 11:44 PM
Default Need help bike wont start 2001 929re
I went out to start my 2001 honda cbr 929re and it wouldnt turn over. I thought it would be the battary, so i took it in and got it tested, it was fine. So talked to a friend and he said it might be the rectefire. We took it a part and the wire plug that conected to the stator was fried. So I bought a new rectefire, stator and cover. I replaced them and it still wont start. I think there might be a short somewhere because all the lights are after marke and the wiring doesnt look to good. If anyone can think of something else that could be wrong with it please let me know. Your addvise would be appriated. Thank you
Old 11-14-2010, 05:14 PM
Sounds like you have 2 problems. Your stator/rectifier issue would only result in a dead battery/stalling. If the battery is fully charged and it won't turn over then it could be battery connection, relay, starter button or other electrical like neutral switch, stop switch, etc. I'm sure someone with more knowledge will come along. You might try 12v to the starter to be sure it is working.
Good luck!
Old 11-15-2010, 08:20 AM
Next to your fuzes there is a relay for the starter with it's own fuze. Check the fuze, if it's good then you'll also see 2 allen screws on the relay with larger wire. Take some spare wire and carefully touch the two screws together. This will bypass the relay entirely and connect the starter directly to the battery. If the starter turns over you know to next check the relay by forcing the trigger via the battery, again if it turns move on to the starter switch, neural switch, and bank angle sensor. Or it might just be a bad ground...
Old 11-18-2010, 11:21 PM
I went to a local bike mech and he said to do the same thing to the 2 screws. He said to turn the key and the switch and it should turn over. It didn’t turn over it just sparked and the lights turned off. I didn’t, however pull the trigger though. I tested the battery and there was only 10 volts? Would that be a problem in the connection and cause it to not start? Should I have pulled the trigger? So does that mean I just need to replace the starter relay and battery or is there something else wrong?
Old 11-19-2010, 09:25 AM
April 2011 Ride of the Month
have you checked your fuse box yet i popped a fuse the other day my bike would prime but no cluster lights would come on and it would turn over but not fire....
i was pissed because i thought maybe ide bumped a wire putting my integrated mirrors on turned out ide just blown a fuse..... check there....
Old 11-21-2010, 09:30 PM
10V is too low for a lot of bikes. They get really picky about voltage levels. Some batteries are bad and show 12V with no load, but can't pass enough current and it will drop to a low voltage as soon as the starter tries to fire up. A lot of people are also against jumping a bike with a car, but I've never had an issue. Try hooking to any larger 12V battery you know is good, or take yours into a battery shop and have them test it.
Old 11-22-2010, 09:44 PM
Sprock's Avatar
Reckon in the process of your rectifier and stator getting fried , your battery got
cooked good too. I'd question the battery passing the load test.
10 volts on a battery basically means it's almost fully discharged
recommend you get yourself a good GEL type battery
Old 11-27-2010, 12:58 PM
WallyAZ46's Avatar
Your regulator/rectifier is responsible for turning ac to dc and monitoring your battery charging. When that melted down your battery was either hit with too much or too little current. I bet the "test" at the shop was the guy putting a volt meter on it and not properly load testing the battery. Toss it and put in a new battery.
Thread Thread Starter Forum Replies Last Post
2001 F4i wont start dgk600f4i F4i - Main Forum 2 05-07-2011 06:17 PM
929RE won't start! Help!! taelvin CBR 929RR 1 04-04-2011 01:26 AM
2001 cbr f4i wont start roho F4i - Main Forum 23 01-22-2011 06:28 PM
2001 f4i wont start!!! help please jeffjones08f4i F4i - Main Forum 11 09-10-2009 10:00 AM
2001 929 wont start help! johnnyjjohnnyj General Tech 4 02-15-2007 04:32 AM
Tags
2001, 929, 929re, 929rr, bike, cbr, homda, honda, put, start, turn, turns, voltage, wont, wrong
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
